It is currently Sat Jul 19, 2025 6:58 am
 Post subject: Alvarez truss rod?
PostPosted: Sat Jul 26, 2014 8:59 am
First name: Patrick
Last Name: Hanna
State: Missouri
Hi, Friends,
A friend brought over an old Alvarez steel string dread yesterday and asked me to help him diagnose some string buzzing. It was a pawn shop purchase several years ago. There is no excessive fret wear and I can't find any loose or popped frets. I believe the problem is a very slight back bow in the neck. It's one of those things that's barely visible, but I can just barely rock a long straight edge from the center of the neck to either end.
I have not yet taken the string tension off, but will do that later today and check the "rock" again. If my hunch is correct, I believe a minor truss rod adjustment will go a long way towards fixing this guitar.
I believe this is a two-way truss rod. It's accessed through the sound hole. If this were a compression rod (as on the instruments I build), I'd adjust quarter-turns at a time--turning counter-clockwise to loosen the rod. Is this also true on a two-way rod? I realize two-way rods work differently. Oh...I would do this with string tension off.
Thanks. Patrick
 Post subject: Re: Alvarez truss rod?
PostPosted: Sat Jul 26, 2014 6:05 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Never mind. I fixed it.
